Autore Topic: Himoto Rancho Pro 1:8 di Igi  (Letto 4117 volte)
Offline IGI
  • Post: 32
« il: 09 Maggio 2007, 17:15:59 »
« Ultima modifica: 15 Maggio 2007, 14:43:21 da IGI »
Offline IGI
  • Post: 32
Re: Himoto Rancho Pro 1:8 di Igi
« Risposta #1 il: 09 Maggio 2007, 17:19:40 »
Specification:
Length : 490mm( 19.3")
Width : 400mm (16")
Height : 260mm (11")
Wheelbase : 320~330mm (12.6"~13")
Front Thread: 300mm 12"
Rear Thread: 305mm 12"
Weight: 3950g
Gear Ratio: 17.9:1
F/R Wheel Diameter: 155*80mm
Distance from Chassis to Ground Level: 78mm
Tank: 125cc
Engine : M28 P3 SH Engine
PACKAGE INCLUDE:
(1) 1 x BRAND NEW .27SH Japan ENGINE
(2) 1 x 1 x 1:8 SCALE PAINTED NICE HUMMER BODY CHASSIS
(3) QUALITY GS FM RADIO SPORT WHEEL RADIO CONTROL SYSTEM
(4) FULL ENGLISH MANUAL
Feature:
Similar as Kyosho Mad Force
Four Wheel Straight Shaft Drive System
Reverse Gearteeth Double-head Lever
Wholly Net Steel Centre Straight Gear Rim
Bulit-in Centre Gear Rim Within Adjustable Pressure
High Speed Bearing Adopted in Fully Vehicle Assembling
6061/T6 Aluminum Plate in Whole Vehicle with Anodic Processed
Universal joint with Specially High Solid Processed
Wheel Rims in their Colurful Radiating Style
Solid Chassis in Superior Quality
Super Toughening Nylon Applied to Total Plastic Accessories
Disc Brake System
Equipped with Small Different Speed Gears in the Lower Gravity Style which can Largely Lower the Entire Gravity
Oil Tank including High-density Filter Lamp wick and Isolated Oil Carrying Device
Built in 6 mm Front & Rear Assistant Lever
Offline murgeu
  • Post: 4334
« Risposta #2 il: 09 Maggio 2007, 17:24:37 »
Offline IGI
  • Post: 32
« Risposta #3 il: 09 Maggio 2007, 17:27:24 »
Grazie!!! :)
Scusa l'ignoranza ma i vostri che telaio hanno???
Offline Cuccurux
  • Il Cuccu
  • Fondatore / Tech-Admin
  • Post: 4471
    • http://www.ats-srl.it
« Risposta #4 il: 09 Maggio 2007, 17:34:19 »
...omississ..
anche se avendo il telaio piatto si differenzia parecchio dai nostri monster ...omississ...
AJO' Murgeu!!!
guarda che i TVP (Twin Vertical Plates) li hanno i Savage, i Genesis, i Raptor, l'FG e qualcun altro....
LOSI, MTA4, REVO ed altri hanno tutti il telaio piatto  ;)
Saluti,
Il Cuccu
Offline BlackHawk
  • Post: 1159
« Risposta #5 il: 09 Maggio 2007, 17:49:27 »
beh .. tutto sommato bel mostricciattolo sai !  :azz:
scarico laterale a mo di savy  o  truggy ... il motore e' bello massiccio (nel senso che e' un big block .. .28 e' un 4.5 mi sembra) .. di miscela probabilmente ne consumera' un pochetto ...
come serbatoio dubito tu possa aumentare ... quello che monta sembra essere calcolato al mm ...  ???
bello bello !  :gioco:
non ci resta che avere le tue impressioni di come va !  :yeah:
Offline Pietrodrums
  • Post: 3526
« Risposta #6 il: 09 Maggio 2007, 17:53:13 »
si dai alla fine non sembra male!
poi facci sapere come va
Offline Leone74
  • Presidente ITT
  • Post: 5747
  • Italian Truck Team
« Risposta #7 il: 09 Maggio 2007, 23:53:31 »
bisogna provarlo prima di giudicare solo dall'estetica!!  :gioco:
Offline IGI
  • Post: 32
« Risposta #8 il: 10 Maggio 2007, 11:27:38 »
Offline IGI
  • Post: 32
« Risposta #9 il: 10 Maggio 2007, 13:50:19 »
« Ultima modifica: 10 Maggio 2007, 16:06:49 da IGI »
Offline showa_91
  • Post: 1833
    • BuisnessGDI
« Risposta #10 il: 10 Maggio 2007, 15:35:24 »
Beh,il savage 25 ad esempio la marmitta originale la ha di plastica :lacrimone:
Offline IGI
  • Post: 32
« Risposta #11 il: 15 Maggio 2007, 14:57:55 »
« Ultima modifica: 25 Maggio 2007, 16:23:06 da IGI »
Offline showa_91
  • Post: 1833
    • BuisnessGDI
« Risposta #12 il: 15 Maggio 2007, 14:59:41 »
Offline IGI
  • Post: 32
« Risposta #13 il: 15 Maggio 2007, 15:27:21 »
Offline McGisto
  • Post: 394
« Risposta #14 il: 16 Maggio 2007, 00:50:41 »
sono curioso di sapere come ti trovi con quel monster...
fagli fare 1 salto di 1 metro ...
SAVAGE X...una bomba!!!
