Autore Topic: help me losi lst2 e losi aftershock  (Letto 1606 volte)
cengenesis
« il: 09 Aprile 2007, 07:51:16 »
Maneba
Re: help me losi lst2 e losi aftershock
« Risposta #1 il: 09 Aprile 2007, 08:58:50 »
Basta andare sul sito del produttore, ragazzi non siate troppo pigri...
AFTERSHOCK
Type:   Monster Truck
Length:   22 in
Width:   18.5 in
Wheelbase:   14.2 in
Weight:   13 lbs
Chassis:   Double-deck aluminum
Suspension:   4-wheel independent
Drive Train:   F/R diffs, 2-speed with slipper clutch
Tire Type:   Claw rubber tires w/foam inserts (preglued)
Motor or Engine:   Losi Sport M26SS engine
Radio:   JR XR2i computer pistol grip
Servos:   Z-590 x 2 (steering) Z-270 x 1 (throttle/brake)
Speed:   40+ MPH
Kit/RTR:   RTR
Shock Type:   Oil-filled, coil over Mega Shocks with threaded collars
Body:   Factory-decorated polycarbonate
Ball Bearings:   Complete
Fuel Tank Capacity:   171cc
LST2
Product Specifications
Type:   4WD Nitro Monster truck
Scale:   Monster Truck
Length:   22 in (559mm)
Width:   18.5 in (470mm)
Wheelbase:   14.2 in (361mm)
Weight:   13 lbs. (5897g)
Chassis:   Dual-deck aluminum with composite ladder braces
Suspension:   4-wheel independent H-arm
Drive Train:   Center Hi/Lo trans, 2-speed w/slipper and 2 differentials
Tire Type:   ATX low-profile racing tires
Motor or Engine:   Mach 427 (.427cc) with tuned exhaust system
Radio:   JR XS3 Synthesized FM system
Servos:   Z590 (steering x 2), Z270 for throttle/brake & shift
Batteries:   1100MAH NiMH receiver pack
Charger:   110v, 100MAH overnight charger
Speed:   40+MPH
Wheel Size:   40-series using 20mm drive hex
Kit/RTR:   RTR
Shock Type:   Oversized threaded coil-over mega shock
Body:   LST2 Racer type, prefinished
Fuel Tank Capacity:   220 c.c.
cengenesis
« Risposta #2 il: 09 Aprile 2007, 09:05:16 »
« Risposta #3 il: 09 Aprile 2007, 11:19:05 »
Offline spike
  • Post: 441
    • http://beagletown.tk
« Risposta #4 il: 09 Aprile 2007, 13:57:23 »
« Risposta #5 il: 09 Aprile 2007, 14:06:56 »
Offline spike
  • Post: 441
« Risposta #6 il: 09 Aprile 2007, 14:23:19 »
considera che se vuoi la retro deviaggiungere anche radio e ricevente nuove a 3ch
« Risposta #7 il: 09 Aprile 2007, 14:25:31 »
cengenesis
« Risposta #8 il: 09 Aprile 2007, 16:09:47 »
« Risposta #9 il: 09 Aprile 2007, 16:16:14 »
cengenesis
« Risposta #10 il: 09 Aprile 2007, 16:32:38 »
Offline powercorte
  • Post: 841
« Risposta #11 il: 09 Aprile 2007, 19:30:07 »
cengenesis
« Risposta #12 il: 09 Aprile 2007, 19:43:14 »
attenzione che a 120 gradi con l'infrarossi corrispondono a 140 con termo sonda!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Offline powercorte
  • Post: 841
« Risposta #13 il: 09 Aprile 2007, 19:47:05 »
lo so...infatti viaggio con temperature troppo alte! :'( :'(
ma d altronde nn so come fare...per farlo stare sui cento devo tenerlo ipergrasso!
Offline Losi93
  • Post: 862
  • "Siamo lenti ma violenti"...
  • I miei modelli: Losi Lst2-E-Revo-Revo 2.5-Crawler
« Risposta #14 il: 09 Aprile 2007, 20:18:15 »
« Ultima modifica: 09 Aprile 2007, 20:22:02 da Losi93 »
