Autore Topic: Messaggi di stato dei led degli esc della serie Mamba.  (Letto 5476 volte)
« il: 18 Maggio 2011, 15:04:41 »
Visto che mi è stato chiesto, posto il significato dei messaggi di stato dei led degli esc della serie mamba, tratto dalle Faq della Castle creations a questo link
http://www.castlecreations.com/support/faq/faq-mamba_monster.html#monster12
The LEDs can have different meanings depending on what you are doing.
If you are not calibrating and have no throttle input:
Flashing Red and Yellow = over temp
Flashing Green and Yellow = low voltage cut-off(battery)
Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0.
Solid Green OR Red = should not happen when at neutral, indicates full throttle/reverse
Flashing Yellow = possible problem with controller
Solid Yellow = indicates neutral and armed
Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
If you are applying throttle or reverse when NOT calibrating:
Flashing Green OR Red = indicates partial throttle (green) or reverse (red)
Solid Green OR Red = indicates full throttle (green) or reverse (red)
Solid Yellow = should never happen
If you are applying throttle or reverse WHEN calibrating:
Flashing Red and Yellow = should not happen when calibrating
Flashing Green and Yellow = should not happen when calibrating
Flashing Green OR Red while beeping = indicates speed control is looking for full throttle (green) or full throttle (red). If it continues for more than ~ 8 seconds, indicates speed control is seeing partial throttle (green) or reverse (red), increase endpoints on transmitter so speed control sees full throttle/reverse.
Solid Green OR Red = indicates full throttle (green) or reverse (red) has been read
Flashing Yellow = speed control is not seeing a valid neutral signal, check your transmitters throttle sub-trim is at zero, exponential is set to 0 or linear, and mixing is disabled.
Solid Yellow = indicates neutral has calibrated and is armed
Flashing all colors = speed control is not receiving a valid signal from the receiver. Usually indicates the receiver wire is plugged in backwards into the receiver; also happens when speed control has accepted a calibration setting (throttle, reverse or neutral) and flashes/chimes 4 times before moving to next calibration point; or problem with throttle channel on receiver.
Re:Messaggi di stato dei led degli esc della serie Mamba.
« Risposta #1 il: 18 Maggio 2011, 15:06:19 »
Quindi Ivan, se il tuo esc lampeggia giallo, dopo la calibrazione del neutro, significa che non ha preso bene la calibrazione.
Riporta tutti i trim a zero e rifai la calibrazione di gas-freno e neutro
Offline Daitarn3
  • Post: 943
« Risposta #2 il: 18 Maggio 2011, 21:31:20 »
Traduzione in italiano ehhh
Visto Che mi Stato e chiesto, Il posto Significato dei Messaggi di Stato dei led degli esc mamba della serie, Tratto Dalle Faq della Castle Creations uno NB Tutti gli ingredienti http://www.castlecreations.com/support/faq/faq-mamba_monster.html link # monster12 I LED possono avere significati diversi a seconda di cosa si sta facendo. Se non sei calibratura e non hanno alcun contributo di carburante: lampeggiante rosso e giallo = over temp lampeggiante verde e giallo = bassa tensione di cut-off (batteria), verde lampeggiante o rosso = controllo della velocità non è stato calibrato e non è armato, o sub farfalla -trim non è a 0. Solid verde o rosso = non dovrebbe accadere quando al neutro, indica pieno gas / reverse Giallo lampeggiante = possibile problema con il regolatore di Solid Yellow = indica neutro e armati di tutti i colori lampeggiante = controllo della velocità non riceve un segnale valido dal ricevitore, indica in genere il filo ricevitore è collegato a ritroso nel ricevitore; possibile problema con il regolatore o con il canale del gas sul ricevitore. Se si applicano a farfalla o inversa quando NON calibrazione: lampeggiante rosso e giallo = over temp lampeggiante verde e giallo = bassa tensione di cut-off (batteria), verde lampeggiante o rosso = indica farfalla parziale (verde) o inversa (rosso) Solid verde o rosso = indica tutto gas (verde) o inversa (rosso) Giallo lampeggiante = possibile problema con il controllo solido giallo = non dovrebbe mai accadere lampeggiante tutti i colori = controllo della velocità non riceve un segnale valido dal ricevitore, indica in genere il filo del ricevitore sia collegato ritroso nel ricevitore; possibile problema con il regolatore o con il canale del gas sul ricevitore. Se si applicano a farfalla o inverso quando la calibrazione: lampeggiante rosso e giallo = non dovrebbe accadere quando la calibrazione e giallo verde lampeggiante = non dovrebbe succedere durante la taratura lampeggiante verde o rosso, mentre il segnale acustico = indica il controllo della velocità è alla ricerca di Full Throttle (verde) o totale valvola a farfalla (rosso). Se continua per più di ~ 8 secondi, indica il controllo della velocità è vedere acceleratore parziale (verde) o inversa (rosso), incrementi
« Risposta #3 il: 18 Maggio 2011, 21:39:24 »
Nooooo Daitarnn... ti prego..
ma se per caso succede questo..
"""""Se si applicano a farfalla o inverso quando la calibrazione: lampeggiante rosso e giallo..."""""
che bisogna fare???
io ho imparato l'inglese a 45 anni per via del modellismo per poter parlare e scrivere con gli americani.. e con tutto il resto del mondo..
sforzatevi anche voi.. ce la potete fare..
e poi mi hai tradotto in italiano anche le mie frasi in Italiano.. :D :D
Offline Daitarn3
  • Post: 943
« Risposta #4 il: 18 Maggio 2011, 21:45:20 »
Non ti arrabbiare lo so che sei un grande l'ho fatto solo per dare un occhio io non parlo inglese purtroppo e allora lo zio bob le mi aiuta intanto ho testato il nuovo i- pad 2 non volevo di sicuro mettere becco ti chiedo scusa non mi permetterei mai di offendere un maestro scusa
« Risposta #5 il: 18 Maggio 2011, 22:30:02 »
Dai.. era per scherzare e per sottolineare che i traduttori ancora non sono perfetti..
altrimenti se si applica la farfalla o inverso quando la calibrazione, succede un casino!!  :risatissima: :risatissima: :risatissima:
Offline Daitarn3
  • Post: 943
« Risposta #6 il: 18 Maggio 2011, 23:28:15 »
 :) vero bisogna stare attenti
« Risposta #7 il: 19 Maggio 2011, 00:00:19 »
Ma perchè??? La mia guida tradotta in ITALIANO comprensibile ::vocabolario::, non andava bene??? :botte: :botte: :botte:
http://www.monstertruck.it/forum/index.php?topic=30277.0
« Risposta #8 il: 19 Maggio 2011, 01:12:47 »
in Italiano non si capiva Giò.. per questo l'ho messa in inglese..  :D :D :D
« Risposta #9 il: 19 Maggio 2011, 02:21:37 »
 :P Hai toppato! :dentone:
« Risposta #10 il: 19 Maggio 2011, 10:18:52 »
Il nostro forum ha valenza internazionale..
le cose importanti bisogna scriverle in inglese.. :bleh: :bleh: :bleh:
Offline Sergiot5
  • Post: 74
  • I miei modelli: HOBAO ST PRO BRUSHLESS - MANTUA AMIKA
« Risposta #11 il: 05 Luglio 2011, 12:13:19 »
Sei sempre un grande...
La prima cosa che ho fatto è stata quella di stamparla e portarla in pista (non si sà mai...).
Saluti.
I gioielli non li indosso... li guido!!
