Autore Topic: accoppiamento esc/motore aiuto!  (Letto 816 volte)
Offline jhonnyfazer
  • Post: 664
  • Savage l'invincibile
« il: 14 Settembre 2009, 20:59:05 »
ciao belli!
vorrei sapere se posso accoppiare l'esc cinese che ho con un hpi firebolt 15t senza rischiare una bella frittura ::bun::
l'esc va benissimo con il 540 tamiya del tt01 ma non so con il 15t...
vi posto la foto e le caratteristiche dell'esc in questione e del motore:
200A RC Car Brushed Motor Electric Speed Controller
Model Number : rcps81710
You are buying a 200A RC Car Brushed Motor Electric Speed Controller. It is capable of supplying up to 200 Amps (forward) or 100Amps (backward) of continuous motor current. Its integrated Battery Eliminator Circuit (BEC) powers the receiver from the motor battery, with automatic cutoff of the motor power to preserve receiver power as the battery becomes depleted. It is linear design and will stop automatically if no signal receives.
It is small, powerful, safe and easy to accelerate and operate, which can be used for different type of car.
Specification:
Working Voltage :   6 cells, 7.2v NiCd, Nimh or 2 cells, 7.4v Li-po battery
BEC Current :   5v/1A
Continuous Output Current :   200A forward, 100A backward
Reversion :   Yes
No Siginal, Cut Electricity Protection :   Yes
Dimension :    33.5 x 33.4 x 19.1mm
Net Weight :   ~39g
Package Weight :    ~64g
Re: accoppiamento esc/motore aiuto!
« Risposta #1 il: 14 Settembre 2009, 21:19:14 »
Offline jhonnyfazer
  • Post: 664
« Risposta #2 il: 14 Settembre 2009, 21:29:54 »
