Team Losi Comp Crawler Features:
Compact Front & Rear Locking
(DIG) Center Transmission allows the crawler to overtake obstacles with ease
Front and Rear Solid Axle with
Worm Gear Drive4-Link Suspension offers 70 degrees of articulation and minimizes front and rear axle swing, allowing for more precise handling
Zero Ackerman Steering provides class leading performance with 45 degrees of steering throw
Front and Rear locked differential provides full time 4wd
3-Piece 2.2? Bead Lock Wheels with aluminum outer rings
National Champion 2.2 Losi Rock Claws Tires with foam inserts
Twin Vertical Plate Chassis with adjustable upper shock mounts
4? Aluminum Threaded Shocks with Titanium Nitride (TiNi) Shafts allow the suspension to articulate without any binds.
Durable, telescoping CV drive shafts allow for increased steering range
Aluminum Upper and Lower Suspension Links for added strength
Lexan Grappler Pro body is optimized to USRCCA Rules and allows for clearance of the tires as they articulate
Race Roller Chassis is preassembled; simply add electronics, paint the body and go
Team Losi Comp Crawler Specifications
Type:Competition 2.2 Rock Crawler Race Roller
Scale:1/10 (2.2)
Length:17.5 inches (444.5mm)
Width:10.5 inches (266.7mm)
Wheelbase:12.5 inches (317.5 mm)
Weight:4.18 lbs. (1.9kg)
Chassis:Twin Verticle Plate
Suspension:4-Link
Tire Type:National Champion Losi Rock Claws 2.2
Wheel Size:2.2? Bead Lock
Kit/RTR:Race Roller
Shock Type:4? Aluminum with Titanium Nitride shafts
Body:Clear Lexan Grappler Pro
Part #: LOSA0051 - Team Losi 1/10 Comp Crawler
