New Standard Parts
TORX
* Fully assembled and Ready-To-Run
* Factory finished body shell in new colour scheme's
* Tuned fuelie 23cc engine
* NEW up-rated cylinder giving 10% extra power
* NEW high flow muffler
* 8000RPM clutch as on the Baja SS
* High capacity fuel tank
* HPI TF-10 27FM steerwheel RC system pre-fitted
* SFL-10 large scale steering servo
* 6v sub-C receiver pack
* Receiver with built in fail safe
* Sealed radio box
* Gunmetal anodising on all aluminium parts
* VVC/HD shocks as fitted to the Baja SS
* Revised rear shock tower
* Revised gear ratio for quick acceleration and high top speed
* Viscous torque differential
* Completely ball-raced transmission
* Dual vented steel disc brakes
* All-terrain tyres fitted on bead-lock wheels
* Adjustable rear wing
* Hard plastic skid plates
o Wheelbase: 570mm
o Length: 817mm
o Width: 460mm front - 480mm rear
o Weight: 9.6kg
http://www.hpieurope.com/kit-info.php?lang=en&partNo=10630http://www.modelsport.co.uk/index.php?CallFunction=ShowSpecification&ItemID=32235&CID=EUR
