Autore Topic: setup evx-2  (Letto 1267 volte)
  • Post: 18088
setup evx-2
« il: 14 Dicembre 2008, 12:38:41 »
Ragazzi ho letto le istruzioni dell' emaxx ma non ho ben capito come si fa il set up dell' esc dato che ho montato la spektrum  :okkio:
Citazione
1. Disconnect each of the motor wires between
the EVX-2 and the motors. This is a precaution
to prevent runaway when the speed control is
turned on before it is programmed.
2. Connect two fully charged battery packs to the
EVX-2.
3. Turn on the transmitter (with
the throttle at neutral).
4. Press and hold the EZ-Set
button (A). The LED will first
turn green and then red.
Release the EZ-Set button.
5. When the LED blinks RED ONCE.
Pull the throttle trigger to the
full throttle position and hold it
there (B).
6. When the LED blinks RED TWICE. Push the
throttle trigger to the full reverse and hold it
there (C).
7. When the LED turns solid GREEN, programming is
complete. The LED will continuously shine green
indicating the EVX-2 is on and at neutral (D).
 ::ont:: ::oooooops::
Re: setup evx-2
« Risposta #1 il: 14 Dicembre 2008, 14:15:36 »
Offline Steel Saviour
  • Post: 787
  • Team ForRace
Re: setup evx-2
« Risposta #2 il: 15 Dicembre 2008, 23:20:49 »
2. Collegare due completamente carica batterie al
EVX-2.
questa mi ha fatto ribaltare dal ridere  :risatissima: :risatissima: :risatissima:
Accetta anche alimentatori?  :risatissima: :risatissima:
