Si ho messo 3 x Hitec HS-45HB Karbonite per il piatto ciclico, e un Align DS420 Digital per il rotore di coda.
Align DS420 Digital :
Specification:
Stall torque:0.75kg.cm(4.8V) 1.0kg.cm(6.0V)
Motion speed:0.08sec/60°(4.8V) 0.06sec/60°(6.0V)
Rating voltage:DC 4.8-6V
Temperature range:-20°C~+60°C
Dimension:22.8 x 12 x 25.4mm
Weight:12.7g
Specification:
Torque (4.8v/6v) : 1.0 / 1.2 kg.cm
Speed (4.8v/6v) : 0.14 / 0.12 sec @ 60 deg.
Size : 23.60 x 9.80 x 22.40mm
Weight : 8.00 g
Gear : Carbonite
Motor : 3-pole ferit
Bearing type : 1 Top Ball
Connector : Standard,JR,Hitec,Graupner
